Found 3000 Mah Battery
I'm not sure if I would trust it or if it would work. The dimensions on the Nexus 5 differ from the G2, so it might not even fit. Also, why do they only list the 32GB as compatible when the 16GB and 32GB are exactly the same? :confused:
