Help Found Fix for Ford Sync Issue!!!
scpatl4now
I finally found something to fix the disconnects between my Fascinate and Ford Sync. I had tried the master reset, re-pairing the phone, soft reset. What is causing this is the Ford Sync Auto Update Contacts. I disabled that and voila...I've made 3 calls in a row over 4 mins and no disconnects.
To disable this feature go to the phone menu (on ford) and scroll till you see Auto Update contacts and disable it
