[Free][Application] GPS Speedometer and tools
BeshevGames
GPS Speedometer - this speed application uses your phone's gps module to determine your current altitude, latitude, maximal reached velocity and total distance. The speedometer is a free software for Android devices with built-in GPS antenna. It acts as a normal speed gauge, which you may find in any car, showing the velocity of the vehicle you are in in kph and mph. This app is compatible with phones, tablets and all GPS powered other Android devices.
*Permanently set to KM/H or MPH
*Change your background
*Change needle color
*Choose to keep screen lit(or not) when app is active.
*Added a software menu button if no hardware one detected
*Move to SD card
*Fixed Altitude readings
*Added Google Map view
*Some bug fixes
*Set screen size
*This is an ad-supported application. The ads are located on the bottom of the screen.
There is also a flashlight available in GSpeed. You turn it on and off by simply clicking the green button, located in the top right corner of the app.
In miles per hour (MPH)
You can set the app to kmh or mph.
Some features of the speed app include:
GPS Coordinates
-Shows you your current GPS position - Longitude, Latitude and Altitude, as well as your top speed.
GPS Speed
-Your current speed and your maximum velocity, according to the satellites.
Google Maps for newer versions of Android (4.0.3 and above)
-Added Google Maps view. With a single click you can view your current position on the map, which may help you navigate to your current destination.
Vehicle position
-The pitch and roll of the vehicle you are in (the device must be in upright position according to the vehicle)
Units
-Both the analog and digital speedometer views can be either in miles or kilometers per hour.
HUD - heads up display
-You can switch to HUD mode, which will show you your velocity digitally with large green numbers.
Mirror HUD mode
-A mirror view of the digits, allowing you to put your phone on the dash of the vehicle, so that the readings of your speed in kilometers per hour can be reflected from the windshield at night.
* Satellite signal (SNR) bar chart. Green bars indicate that the current satellite is used in the fix, while the blue ones show that the satellite is visible, but it is not used for a position fix.
* GPS satellite status and information, shown in a scrollable window - the number of the satellite, whether it is used in a fix or not, Signal-to-noise ratio, azimuth.
* The number of fixed and all visible satellites.
* Compass, which will also show your heading (if the device has a build in sensor).
* Information of your location - your current latitude, longitude and altitude.
* Accuracy window
Legend:
---Satellite status---
*N: - PRN (pseudo-random number) for the satellite
*Fix: True or False - if the given satellite is used in a fix for the location
*S.N: signal to noise ratio
*Azi: Returns the azimuth of the satellite in degrees. The azimuth can vary between 0 and 360
---Info---
*Lat: Get the latitude, in degrees.
*Long: Get the longitude, in degrees.
*Alt: Get the altitude if available, in meters
---Accuracy---
Get the estimated accuracy of this location
The sequel to the well known mobile game Keep It Safe - the players will again take control of a vehicle, racing through a hilly terrain, so that they can transport various cargo to the final destination (the shop), keeping it safe. Their goal is to accumulate as much finances as they can to unlock the next vehicle, upgrade or level, each different from the other. Race to the finish, keeping the cargo safe at the same time.
Game features:
-Physics based game, making it very fun
-Currently 5 different vehicles: 2 cars, 2 pickups and 1 truck to transport the cargo. More soon to come
-Added trailer
-All vehicles can be upgraded - you can upgrade their engine, add different levels of 4x4(all wheel drive), as well as their suspension.
-Currently 4 levels, I will add more in the future
-Very interactive menus
-The timer only starts if you have any cargo in the vehicle. Else you can drive freely, exploring the level to get to know it better.
-There are two pedals, one for gas and one for braking / reverse. There is also the optional handbrake, which will help you while loading the cargo.
-Various goods, each with different characteristics and physics
-Custom drawn game graphics.
-Audio settings
