Free mp3 player with crossfade function?
I use Gone Mad- i just looked it up on play store and it says 14 free trial, but i can't recall if it still works with limited function. it does have crossfade. i tried a lot of music apps and really like this one, but i'm sorry i'm not certain regarding your question- i've had it for some time and eventually did buy it. try it and see. hope this helps!
https://play.google.com/store/apps/details?id=gonemad.gmmp
Try Power Amp. I've been using it for a few years. It has crossfade, the ability to edit my data and sources for album covers, manual eq and pre sets, and lots of skin choices. You can add covers from your gallery as well. I've had it for a couple.of years and the guy will.answer you quickly if you have a questions.
Poweramp isn't free though. It's a paid app with a 15-day free trial.
I enjoyed using Gone Mad, but I noticed it doesn't work anymore when the trial is expired. Before considering to buy it, I want to know first if there does an mp3 player app exists with crossfade for free.
Thank you in advance.
sorry- i couldn't remember the limitations after the trial. good luck! any questions on GoneMad let me know--
