Fresh 1.1 Initialize Fresh ROM
pbp776
Member
Hi, I followed all the steps from [Guide] Root/ROM FAQ/Tutorial and installed Fresh. However, when the phone comes up everything is [OK] but in the bottom Initialize Fresh Rom [Wait] flashing. It keep on rebooting and comes to same point for past 30 minutes. Did I messed the rooting part or ROM installed? Is there anything can be done here? or do I wait?
pbp
How? I'm holding End key and nothing happens. is there a hard reboot or power off ? Should I remove the battery?
Hold HOME when powering it on, and you'll come to the recovery screen. Select "apply SD: update" (or something like that lol). And select the Fresh 1.1 zip that's on your SD card.
Should I go back to original stock rom from the backup? I reapply the Fresh ROM and again it flashing [Wait] for past 10 minutes then rebooted. It rebooted three times again and same thing.
Ok Restored from my backup. Now it at the HTC screen for 20 minutes now.. I'm out of idea.. Any help or direction?
I've been having the same issue when restoring backups...it just hangs at the HTC screen. I haven't been able to figure it out yet.
I removed the SDCard and I was able to bring the phone up. Not sure if SDCard is bad or or something on SDcard got corrupted. At this point I have to phone up with out the SDCard. As soon as I put SDCard it get hung during the boot process.
