Root Fresh 3.501 Out for All
not having very good luck with this rom...flashed 3.5 for doners...and just flashed 3.5.0.1...and now almost all my programs are force closing, launcher pro won't open...going to try wiping and then flashing to see if it helps...
i tried flashing smooth sense after i put 3.5 on there and it kept boot looping on me and had to go back to my 3.4 backup then install 3.5 agian
i can live w/o it but just a heads up to anyone else who had smooth sense
I heard some people having issues flashing on top of 3.4... I had no problems as far as flashing one on top of the other, but I did have an annoying 100% awake time issue (found out is was do to me being on an older radio). I factory resetted my device and flashed 3.5 fresh... had no awake problems or issues in general. Plus my data speeds are faster... still testing out battery life tho, but its working great so far.
I'll try a full wipe tomorrow
I flashed Fresh 3.5.0.1. I did modify the notification bar widget.txt file to my liking. Now when I use the airplane widget with the notification bar my 4G is backwards. When I turn on airplane mode the 4G widget and antenna turns on (it should turn off), and when I turn off airplane mode the 4G button and antenna turns off. The 4G button is backwards from what it should be.
If I use the HTC Airplane widget everything works normal. It is just the Notification bar airplane widget that is backwards.
Anyone else noticing this? Any suggestions on how to correct?
Here is what is in my widget.txt file...
toggleFlashlight|toggleWifi|toggleWimax|toggleBluetooth|toggleSound|toggleAirplane
Any other thoughts on Fresh? I've been reading mixed reports on the latest release, I want to get a little reassurance that it's reliable before I update.
I'm using SteelROM with the latest radios, so I believe I only need to update the OS, not the radio fimrware, correct?
Thanks!
Hey Guys..
Loaded it last night... so far so smooth..
On HBOOT 2.10.... fact reset...
BOOMVIOLA rooted and smooth...
How is Bat life for the rest of you folks runnin this?
TY
Gatr
Yip, I loaded it too and really liking it so far. No naughty power management so far. I should note that I'm using the older PRI (1.77), I reluctant to change it yet, since I've read so many reports of issues with the later firmware.
I have a new EVO and couldn't root it until a few days ago when the unrevoked 3.3 came out. So today I finally had the chance to burn Fresh 3.5.0.1 on to my EVO. Although others suggest it might not be optimal, I went ahead and used ROM Manager (and thus most recent Clockwork) to load the ROM just like any other ROM. 4G, WiFi, the Android Wireless Tether, GPS, and camera are all working just fine for me. Market updated right away and I already had current radios/PRI on board so no update to do there. I'm only a day into 3.5.0.1 but for me it's been good. I used adb to push a widget.txt file onto it to customixe the notification area widgets to include 4G toggling.
Here's a fix if you have the one problem I had: Navigator just hung for me even after reboots. A dialog pops up about checking on navigation and just stays there forever. But I went into google maps, searched for a location, then pulled up directions to it, and navigator worked fine... hasn't recurred since. I can replicate the behavior by reflashing the ROM and it does it again. Once you go into maps one time and start navigator from there, it doesn't hang any more.
But everything is A-OK and not one thing I've found not working. One of the advantages of Fresh is it's always based heavily on stock Sprint/HTC so it's gonna be close to bulletproof.
3.70.651.1 / HW 0003 / Bootloader 2.02 / PRI 1.90_003 / rooted via unrevoked 3.3 / ROM flashed using ROM Manager and CW
I flashed this last night and it feels great! Only problem I have is I can't get Winamp to sync wirelessly. Still gotta fiddle with it more though. Neato!
I tries this ROM today. It got in some kind of loop while booting up and it said "Fresh" every 10 seconds or so. Very annoying. After 10 minutes, I put Azrael back on. I love that ROM.
I loaded this about 4 days ago and only problem is so far twice it has started massive battery drain. When not doing this I get over 24 hours a charge, but when it does do it I can lose 50% in four hours. Not sure yet if I am doing something or not. Been working haven't been able to completely lock it down yet.
Did you do a wipe before flashing? I have been running this rom since he released it in December with not issues. I have tried other roms and come back to this one as my daily use.
Yep. Sure did. I haven't loaded a lot of ROM's (myn's, Azrael, fresh, Mikfroyo, stock), but this is the only one I have had a poroblem with.
X... I also have had zero probs w/ this Rom... I always wonder why some folks run some of these things prob free and other have issues... I mean we are all playin w/ the same toys it has always kinda made me wonder???
Salute
Gatr
just flashed myn's 2.2 rls5 but want to try something new and have never used a fresh rom, does anyone know if my flashing the radio for myns will give me problems flashing fresh?
