FriendCaster wont sync Contacts
SamG528
I have it set to sync in my accounts in the menu but for some reason my contacts wont sync with my FriendCaster contacts. When I had the Facebook App downloaded it sync pretty much all my contacts but i uninstalled it for FriendCaster because its better, but this one problem is just making me mad. Any solutions?
Also I have an LG Optimus S
bump. would like to know myself. i dont use facebook anymore on the phone.
found this on another message board:
"I just installed the free version.
Go into your android contacts......display options......go down to the bottom where the Friendcaster profile is listed and hit the dropdown arrow......check All Contacts.....hit done.
does that work? "
I found that although friend caster was set to sync, my accounts were not. I went into my accounts on the phone and manually synced friend caster.
Problem solved.
For me anyway
