FriendStream replacement
Ceefax
I've seen a few people looking, like me, for a replacement to the HTC FriendStream widget for use with other launchers.
Well, I've found one that I think works just aswell. It's called Socialite Beta and i found it on appsbrain here or (crosses fingers it works...) here using the barcode:
img.php
Took a while on setup, which was wierd, but guess it was just due to the mass amounts of things it has to cache (pictures, details, updates etc)
It's a pity you can't scroll through using touch, perhaps its something they'll add if they get enough feedback on it.
Let me know what you think, or if you have a better full screen widget that does a similar job.
It's better than 2 seperate apps, but you still have to switch between fb & twitter and cant send status to both simultaneously as in friend stream. HTC really need to get it sorted.
