Accessories Front case replacement in UK
nemo1966
Hi people, dropped my desire :( No bad damage just the front/outer painted bit has dints in it. Does anyone know where I can get a replacement in the UK?
thanks
HTC make the phone. If you don't want to invalidate your warranty you'd need to buy a replacement facade from them.
I have the same problem. I had a look the net and couldnt' find anything so contacted HTC Tech Support. They guy said there are no authorised repair agents in the UK and it all gets done through them.
He quoted
