Hi All
Could you tell me if the front facing camera on the S3 should auto focus?
I don't get the focus square as I do on the rear camera. The focus appears to be fixed to around 5mm from the lens and tapping screen or taking the photo doesn't auto focus.
Only had the handset a week, so I'm trying to work out if i can resolve or if it's a fault and I need to return.
Thanks
Thanks
