froyo running much slower than 2.1
may2700
ok, i couldn't wait for the OTA, so i manually updated from the droid life site. now that i am running 2.2 my phone is so slow its almost impossible to use. whenever i put the phone in standby then start up the phone to do something, it takes approx 10 seconds to repopulate the home screen and approx 20 seconds before i can swipe to a different home screen.
any ideas what may be causing this?
i am obviously not rooted, i do run live wallpaper and only have 2 widgets (beautiful home and calendar) phone ran great on 2.1
thanks for the help
Gotta be a bug. 2.2 is inherently faster than 2.1 because of the JIT compiler. If it's running slower, something is wrong. I don't know what could be causing this.
Mine was running slow when I first booted it up. Then after about 5 mins it started running fast and smooth. Perhaps you need to power your phone off then restart. If that does not help do a phone wipe.
its so slow now i am thinking of looking for a way to undo the update. i tried to use pandora and it was almost 5 minutes before the music started. there has got to be something wrong with it
ok, went to market and i had updates, so i clicked 2 of the programs and hit update, market downloaded both and we r now going on 10 minutes of it saying installing. i am afraid to reset phone as i may screw up programs. not sure what the problem is but definatly not working right
Yeah, I got the same problem. I hope if I let it sit a while it will take care of itself. Perhaps it's still updating/converting stuff on the first start up.
