Root FroyoRC2 SPRINT Hotspot
I've got the FroyoRC2 now but need to know how in the world do I uninstall Sprint Hotspot? I can't seem to find it in installed apps or in titanium backup.
hotspotremover.zip
Put this into the SDX zip folder. Boot into recovery and apply the recovery. Don't remove the Dalvik Cache at all before tyou apply this zip, do not. Once you apply the zip just boot to system. Thank Quadinar on SDX for this fix.
When you remove the hotspot app does it remove your ability to use other apps, such as open garden wifi tether? I am also interested in removing the app since I no longer need it.
If you are using the legitimate FROYO, you can't get rid of it. This was a FROYO port. If you are on the official FROYO this won't work.
