Help frozen boot - trio stealth pro
barlow
hello and thank you all for letting me join ... i have a bit of a problem ... i have a trio stealth pro (7c i think) and me being the stupid one that i am selected "system" when doing a wipe for factory reset ... i now can not get it to boot past the "trio" screen ... holding "power" and "volume" does nothing but turn on the power light, not even lighting the screen ... so id this now just a flashlight/ paperweight or is there a way to salvage it? any help would be grand, thank you
That is a $45.00 Chinese tablet, so I doubt you will find much manufacturer support.
I think you will need to buy an new tablet.
That is one crazy cheap tablet. I agree with glc, its better to buy a new and better tablet than that.
