Fullscreen picture on the background
WildBoar
May be its a stupid question but when i try to set up a background picture it only allows me to set a part of the picture not the whole picture...
And the other question what bothers me is about the Navigation... is there any free program which doesnt require a network connection for using it like Garmin for Symbian ?!
with the wallpaper you need to make the wallpaper in the size of the phones screen.....
about navigation you can use ndrive navigation
Ok i set the wallpaper at 320 240 pixels and its the same thing... cant take the whole one. What should the size suppose to be?
I don't know, but until someone with more insight than me answers, try just downloading one of the original files off the phone, open on your computer and then you'll have the dimensions exactly.
The correct resolution to save pictures at is 320x240 as previously stated. When you go to change the wallpaper and the small rectangle appears asking you to crop it you can drag one of the 4 corners outwards so that the entire picture is selected. Hope that makes sense...
Works perfectly on my X10 mini
It still doesn't work for me, even though I select wallpaper that is 320 x 240, I drag the rectangle out to contain the whole image but when I go to the home screen only the centre of the image displays ?
Ah ok, but if you swipe left or right on the home screen do you see the rest of the image?
I believe the image is split across 3 screens by default
I'd say it is even more than 3 screens! I have 6 widgets on my home screen so every time I swipe I see a little bit more of the image - but again only the central part there is no way of seeing the upper or lower part :mad:
Does the full image appear when the phone is in landscape mode?
The screen does not rotate when at the home screen so everything stays the same - when viewing the image in the photo album they are fine, a nice, clear full picture - it's just when you select to use it as wallpaper it seems to just enlarge - I think it is something to do with the widgets like you suggested, I reckon if you probably only had one widget installed it may be okay - but what good is only having one widget on your home screen!
on all my android devices the wallpaper is spilt so a bit is on all screens
I believe, on the X10 Mini (i dont have one, I have the full size one and was gonna get my partners mum one) that, because of the small screen space, while the X10 has three screens, the X10 Mini has unlimited screens because you can only have one widget per page.
I would have thought enlarging the square around the image you want would have done it though. If you select a smaller area of the image, does it just show the center again, or the bit selected?
You can have more than one widget per page if you use a different launcher. I'm using Helix and have 4 widgets on my main desktop screen on the mini
