Help Fusion u8650 Huawei firmware update fail.
robfed4
I found the Huawei firmware update that comes in 2 parts, in two folders...
NOTE: _ = / for this post
dload_update.app
vendor_update.app
You are supposed to use 2 SD cards. One the dload_update.app from the original dload folder and the 2nd SD should have the vendor_update.app in it's dload folder.
I was able to use the -vol + +vol + pwr switch hold to get the phone to start it's firmware update. When the magenta progress bar almost gets to the end. It fails and freezes.
When I remove the battery and reboot. the phone comes up with the update. But I cannot get the 2nd file to load at all.
a. partial dload_update.app - sd card 1
b. no load dload_update.app - sd card 2
But the phone seems to work. But I can only connect to 2G network the 3G icon never shows.
I would like to start over with the stock AT&T firmware, does anyone know where to get this?
Thanks,
Rob
California
