Accessories FYI - Touch Pro 2 Battery works with Incredible
igl007
Don't know how many of you are coming from the TP2 land, but the battery is exactly the same output, except it's a 1500ma vs. 1300. Just tried it in mine and it works great!
If the battery turns out to be crappy - even though it seems to actually be doing fine - I'll be buying a TP2 battery. It will probably be better than the seidio 1750 mA battery and it's cheaper
I just bought one on eBay for $15!
1
OEM HTC TOUCH PRO2 PRO 2 BATTERY TMOBILE SPRINT VERIZON - eBay (item 360255445426 end time May-22-10 08:06:07 PDT)
Will do, although I am a firm believer that it takes a good 2-3 weeks for the battery to be operating at full potential.
I will say that cycling the battery already does seem to improve battery life. I cycle it everyday and it has steadily been improving.
I finally noticed an increase in battery life today. I tried turning off Ll the regular stuff outlined in other threads except WiFi. Just for the hell of it last night was my fourth cycle charging and I turned off WiFi before I went to bed. As of morning I had a full charge still. I've been using the phone pretty heavily today and I still have over 50 percent charge. I don't know if it was the fourth cycle or not but having WiFi off really seemed to help. It's not oh my god better, but really noticeable. One advantage is that verizons 3g is pretty snappy so not having WiFi isn't really noticeable.
I have been getting improved battery life with this left everything on used moderately and have60% left and used it since 8 am
I'm really thinking about picking up a TP2 battery. Keep us updated for those that are using it
I cant really confirm if this helps life or not, but you are automatically logged into GTalk when you sign into your google account when setting up the phone. Go into the app, settings then uncheck automatic login, then logout.
I have noticed better battery life after doing this. Might just be in my head, but its worth a shot, right? :)
Thanks for the tip. One thing I noticed after doing this is that the 'GTalkService' keeps running in the background. Anybody know how to stop this from starting? I killed the service and everything looks okay so far. I don't plan on using using google talk anyway.
That's odd, mine definetly isnt running in the backround on my phone. Maybe try re-setting your phone and see if that helps.
