G-BOX Rockchip 2918 Gingerbread - Really plays and outputs FullHD
I will try this weekend to do root, the device works perfectly, I got a new firmware, but for now way to update is only in Chinese, the only problem I discovered is the power of USB ports is only ~ 400 mA, leading to problems with external HDD's without external power, I have an external 2,5" HDD with USB 3.0, which connect the USB port g-box stops.
G-Box runs perfect HD movies and serials on the Internet (test vplay.ro), without gaps, games (love Mario Android version:)) using wireless connection
I hope to have time to do a review on youtoube
By the way, sorry for my English, but still learn :D
thanks. Where did you get a new firmware from? It would be nice if you can root this box. Would like to know improvements gained from the new firmware.
The first thing I would do after root is to adjust the output scale from 160 to 240.
Cool!
Can you test PSX and N64 emulators and post on youtube?
I got the G-BOX Rockchip too.
So far the performance is good.
One limitation, when I watching a movie, suddenly i want to pause it and asnwer phone call, but I need to press a lots in order to pause it.
Anyway to customize a remote control key to pause/resume movie?
Sorry for my English I am using the translator. I write from Italy.
I received the TV Box Android 2.3, from China.
Wi-Fi crashes occasionally
The device switches off
Graphics ugly
Some websites with the remote control can not be seen.
How do I update the Android TV box?
thanks
Graphics ugly
thanks
Is it the same box as shown in the first post?
Did you try factory reset?
It is the same identical boxes. I did restore the default settings. in your browser.
I contacted the supplier, told me to switch browsers, but does not work the same.
The only problem is the browser, everything else works. I do not understand why, everything works but the browser vendor no.Al I asked said that the update I will send the file.
How do I factory setting?
thanks
After many attempts I solved the problem. I'm happy. I
bought a keyboard and a 2.4 g mause now that works well
Android TV boxes. I downloaded a brawser from Android
market. now truly excellent product. I'm happy with my
purchase. hello all.:)
Hi, I have also just bought this box, the exactly same one from the very first post. I did find somewhere that the firmware can be update with a file update.zip in the sd card but I don't know exactly how to do it. I will try to find this information again and point to that direction. I tried to use the google remote control app to control this box from my mobile and it didn't work, the error message was "Google TV Box couldn't be found on your Wifi nextwork".
Cheers,
Gus.
I found that Wifi connection very slow. Not sure what went wrong.
Any Android expert out there? Need your guideline to root this G-Box
Cheers,
Gus.
Hi...the GoogleTV app is for official GoogleTV products. This G-Box is not GoogleTV, it is Android TV. So the app won't work with this box.
Yep, I knew that but I hoped it would work ;).
I found this link
Video: Here’s how to install the Honeycomb update on your Logitech Revue | Android and Me
and I am tempted to try this on my box. Does anyone tried to install Honeycomb? or Ice Cream Sandwich on their box?
I am not an Android expert but I do try lots of things with android phones, new firmwares, os, etc... and I know that the firmware has to support the hardware on which you are installing it so in theory installing Honeycomb on this device should work, right? right? Please post your thoughts.
Cheers,
Gus.
hi
i found in this site a firmware for box
xxx://www.dayflycn.com/Downloads.asp
but no change log
with rk29xx-imagetools-v21 i unpacked this rom
but i don't know change and repack
for control this box with your phone you can tried droidmote serveur an droidmote client
but first we must rooter this box
sorry for my english
si
Whats the way to root the G-box?
i try once but my computer didn't have the drivers when i connect the device...
or i have to copy on a SDcard and root from there?
thanks man
Hi all,
I received updates from the manufacturer (EC Technology Shenzhen), those who want to update the firmware, you have attached two files, copy both the sdcard in the main directory, start the G-box, then insert the SD card , the device recognizes the update and ask for confirmation, if all goes well after about 10 minutes update is ready, install and keyboard attached, and the settings as default pass it,
This update resolve some bugs, has several applications in addition, is still working on it (I asked a driver for webcam for use with Skype)
for the moment can not be root filesystem is different.
http://www.mediafire.com/?0tk48326p1awrrw,dhczgk2cv2qfkih
now my device lose wifi conection after few minutes working. If i go to reconnect from the settings the wifi conection give me Error and is impossible to activate.
any ideas?
thanks
hi
the wifi is strange but with a static ip, works fine
i tried the visio on reelportal
with a logitech e3500 video it's ok (it's great for a usb webcam))
but the song don't work
why?
update is attached to the link posted above, I installed the firmware posted hotlink is ready root, with some small touches go ok. The WI-FI works OK
@Orefie, have connected a webcam and go (E3500)?
