Flashed it, and though it had a ton of customizations, I went back to Codename Android 1.6. Codename is the best ROM out, in my opinion. Liquid seemed choppy for me at times compared to CA.
(Regardless of what I just said, Liquid is a good ROM.)
OK so I updated my ROM to LiquidSmooth v1.3 which comes with Franco kernel. I set all my setting to the same as before and my results have dramatically decreased...
If you just flashed the ROM I would give it some time to balance itself out. It might be doing other things in the background that's taking CPU time away from the benchmark.
you are paying too much attention to benchmarks...can you really tell a difference between the 2 ROM's speed wise? probably not.
dont look into benchmarks too much...real world use is where its at. i can crank up my phone to 1.4ghz and blow up quadrant with 4000 scores...but does it feel any faster than when i had it at 1.2ghz? no
