Hi all, i hope this is the right place for this.
Recently my g1 has started using 3G or GPRS almost constantly, like its auto checking e-mails or somthing.
If i disable the 3G option it uses GPRS insted
I have reset the g1 to factory defauts, only APNdroid and ToggleWIFI installed, but it still keeps doing it.
(APNdroid was installed so i could turn off ALL 3G/EDGE/GPRS connections)
Strangely this does not happen if the WIFI is connected, and if "Data roaming" and "2g networks" are UNCHECKED in SAFEMODE the "G" symbol appears(GPRS), insted of the 3G symbol.
This is slowing down my connection when i do use GPRS/3G/EDGE.
Why is this happening ??? and how can i stop it, without using APNdroid ????
This is a T-Mobile G1, using firmware version 1.5, build number CRC37
