G2 to note 2. Should i?
snakkula
I have the LG g2 now but I have the option swapping to a rooted twrp recovery note 2. Is it a good idea? :( Help?! I've never had a tablet like phone.
The Note 2 is easily my favorite of all of the phones I've owned, from my Treo 700P thru my Galaxy Nexus.
I didn't even think about "upgrading" to the Note 3 because I don't think it's a significant enough upgrade from the Note 2.
Since the one you're thinking about getting has TWRP then if you don't like the TW features you can install an AOSP ROM.
What are some good features about the phone, and can anyone explain to me about twrp because I'm not familiar with rooting at all.
I bought it mainly for the screen size, but the multi window feature is nice.
Others use the s pen a lot more than I do. They use it for actually taking notes, I prefer to open an app and type.
I mainly use the s pen for creating photoshop type pics in s note.
It also has the gimmicky features such as smart stay and rotate. The camera has cool features like only showing the color blue, green, or red and yellow when taking pictures.
TWRP is a custom recovery. With it you can do nandroid backups which backup the entire phone and you can restore that backup if you need to do so.
It is also used to restore certain parts of the backup such as the kernel and system. It also clears cache, davlik, factory reset, fix permissions, and of course flash new ROMs or mods.
as above, it is my fav phone of all time ( I started with bt celnet and a brick with a pull out antenna pmsl) cant see me upgrading from it for a long time now. had note 2 since launch ang upgraded from a galaxy s1.
