Help Galaxy 3 ( I5801) Too Many Pattern Attempts in
kannanmdu
Hi All
As happened to many of others, I also forget the unlock pattern and under panick I have exceeded the number of attempts and now I have landed up with my phone displaying the user name and password fields asking for the gmail account credentials
I have tried entering my gmail account credentials but it is not solving the problem. I have searched in this forum and other forums also bot could not find a fix specific for GT-i5801 ( Galaxy 3)
I tried event to hard reset by the three key ( VolDown + Home + Power ) method also
Can any body help me in solving this problem? I am not even worried about the data as i have the backup of contacts which are the only data i have ( Afterall the phone is just 1 week old)
Thanks in advance for any help
Regards
Kannan
Chennai, India
Dear All
After all pondering i finally solved the issue ( Though i lost all the data, my phone is back alive )
I did the following to hard reset
1. Switched off the Phone
2. Press ( VolumeUp + VolumeDown + Home ) and then pressed the power button while holding the three buttons and i got into boot menu
3. Slected the wipe data / factory reset option
4. An exclamation mark with android man logo will be displayed
5. After some 10 - 15 minutes i pressed the Home button and i got the boot menu again
6. Selected reboot and it gave another logo ( Open box with android man logo ) and i pressed the home button to reboot the phone in the fresh factory condition
Lessons learnt
1. Never ever use Unlock pattern if you are not able to remember
2. Backup your phone regularly ( Luckily i got my contacts back up atleast)
Hope this helps somebody with the same problem
But please note that all the data will be lost so think before you do anything
Regards
Kannan
Well, I had the same problem and i was in a panic... Luckily I solvd it the next day using the same method...
@ 7checkmate: unfortunately, this can be done by anyone if only he/she knows about it.. At first I myself had a hard time finding out the way 2 get in2 recovery mode..!
after that,i tried to go into the recovery menu again,and now the phone is stuck inside the recovery menu,HELP!!!I CANT GET OUT OF THE RECOVERY MENU
keep the power button pressed in recovry mode and it will reboot..
or try removing the battery if above doesnt work
@strike402me:- My phone got stuck in the recovery mode (twice)...both the times i took it to the service center to get is repaired...guess they'll flash the os again...
Hi All
Regards
Kannan
Chennai, India
Many thanks for your full proof solution...., It worked fine on my i5801....
Thanks a lot for ur valuable post!!!!!
it saved my life......
my 1 month new 15801 after installing an adw theme started force closing today....
cudnt do anything....der wasnt even a home page.....
was really shocked and scared dat i messed up my phone....
i have done wat u have said and kept it for the 15 mins time u said....meanwhile thought of thanking u.....hoping it will b fine!!coz this is d only way to bring it bak!!!!
THANKS A LOTTTTTT!!!!!!!
advise to all 15801 users:be careful while installing adw themes....d one troubled me was a tortuga theme...
dear all
after all pondering i finally solved the issue ( though i lost all the data, my phone is back alive )
i did the following to hard reset
1. Switched off the phone
2. Press ( volumeup + volumedown + home ) and then pressed the power button while holding the three buttons and i got into boot menu
5. After some 10 - 15 minutes i pressed the home button and i got the boot menu again
6. Selected reboot and it gave another logo ( open box with android man logo ) and i pressed the home button to reboot the phone in the fresh factory condition
lessons learnt
1. Never ever use unlock pattern if you are not able to remember
2. Backup your phone regularly ( luckily i got my contacts back up atleast)
hope this helps somebody with the same problem
but please note that all the data will be lost so think before you do anything
regards
kannan
it worked.......thanks a lott!!!!!
No more themes from now!!!!!
i reset the phone with the above mentioned method but now i cant connect to airtel.. nothing shows up in the networks but cellone and that isnt authorized...
Hi Kannan,
Thanks a lot for the great useful post.
It saved the day for me and brought back to life my I5800
Excellent tip. :):):)
Thanks
Rahaman
Chennai
hey thank u sooo much..the first time this problem happened to me my dad did it n gave..now i made the same mistake of puttin a passwrd n forgetting it..so thank u soo much my phone is back..!!:)
Dear All
Kannan
thanks, my younger sister try and try to unlock my phone and the condition is i cant remember my google account password, so i try to follow your suggestion and bwala, thank you so much
It would have been a lot easier to try a pattern 5 times in 30 seconds and then sign into Google account (with password) from the forgot password box that pops up to bypass the lock (only) to reset password.
No hard reset, no loss of data.
