riveraadrian
Member
My Galaxy A10e doesn't want to connect to Wi-Fi and it displays this note with an Boost Mobile Logo: Your phone is not activated. Activate it now at BoostMobile. You can only call Boost Care or 911..
have you talked to boost? is your phone activated? as far as wifi goes, try re-booting your router.My Galaxy A10e doesn't want to connect to Wi-Fi and it displays this note with an Boost Mobile Logo: Your phone is not activated. Activate it now at BoostMobile. You can only call Boost Care or 911..
just unplug the router, wait 30 sec, re plug the router....or there should be a on/off switch.I do not need my A10e to be activated, I'm gonna be using Wi-Fi, and I don't know how to reset an hAP Lite (hint: the hAP Lite is my router)
I can't wait that long.just unplug the router, wait 30 sec, re plug the router....or there should be a on/off switch.
really???????????/I can't wait that long.
I just moved to an ZTE Compel from AT&T and I'm using it right now, even it was my brother's...really???????????/
You can see 2 treads if you search ZTE Compel on Android forms right now, mine has the largest name.I just moved to an ZTE Compel from AT&T and I'm using it right now, even it was my brother's...
Dannydet, I just need another device from AT&T GoPhone and that spam stops
Yeah, that's a spam pop-up. Ignore it or install a ad blocker from the play store
