Help Galaxy ace phone apps not installing
mizzeeboy
Hi there
I have a Samsung Galaxy Ace which is NOT rooted.My phone was working for 2-3 months until none of my Apps were showing.I tried formatting it and hard formatting it but that didn't work.Some help/advise would be very nice.
mizzeeboy
Do you mean that:
After formatting and reinstalling apps, that they aren't visible in your menu?
Or can't you install an app anymore?
Try using AppInstaller or AppManager to see if your apps are visible there?
If not, try setting your install location to Extern instead of internal and see if it works.
