Title pretty much explains it, sometimes the phone just stops receiving calls (it's as if it were off for the person calling and goes straight to vm) and when I try to make calls it takes forever, then a single tone and "call ended" without it even starting. It also happens with sms (receiving end, haven't tried sending one when the problem occurs). The only way to solve this is to restart the phone. Any ideas why this may be happening/how to fix it? thanks!
Edit: I suspected it had something to do with the 3G network so I forced a 2G connection. Issue hasn't occurred since then. Will update tomorrow if Root Cause was 3G
Edit 2: 24 hrs without the problem, feel pretty confident it was the 3G that caused it. Will switch back to see it can be reproduced it
Edit 3: Carrier recognized it was a problem on their end. Solution may take up to one day to be effective, will edit back when I fully test problem is definitely solved
