Wifi is not turning on in my Galaxy Ace. When i tap the wifi icon in the notification bar, it changes to green, but changes back to grey in one second. I am using gingerbread 2.3.4. How can i fix this issue?
Hi, common problem I believe. I get it occasionally on Froyo 2.2.1 (yes I'm still original & loving it!) & it is a problem on GB. Have you tried the *#*#526#*#* fix?? Works for a while, then you have to do it again! Hope this helps in the short-term. Graham
