galaxy ace
sky2011
hi folks,
Iam planning to buy samsung galaxy ace...
from specs and review i found out that flash player is not supported on browser..
Is is rectified noW???
pl suggest and clarify
Thnx in advance :)
i need to buy one this weekend...
few other queries:
1. now that i buy a phone this week...how shud i update my phone ??
2. will flash player be available after updating my phone?
3. should i update from samsung site or android market??
pl help me as iam new to android technology...:(:confused:
1. You can update your phone using Kies depending on the world you are 2.3.3 is being rolled out or you could always flash it yourself but that will void your warrinty
2. It's still not available in 2.3.3 but if you use the skyfire web browser that supports flash.
3.Android Market
hi ppl,
how to save contact of my sim to android phone??
i dont find any option..
pls help..
Thnx in advance
thnx buddy for helping me with contacts..
I have another query..
I dont find a sign out option in gmail app...
can u guys pl help
hi
go to contact, push the left key, and select import/ Export. there is what you need.
hi... can we play wma format music on ace?
iam not able to play with default musioc player... i tried using winamp and tunewiki too.. no use :( pl help..
thanks...!!
Hi, the Ace will not play wma music. You will need an audio converter to convert to mp3. (search on Google there are a few good ones for free). Convert music on your pc & copy back onto your SD card. Hope this helps. GrahamF. London :)
