A
AllenWell
Guest
Hi, hope you can help me. I tried to root my Galaxy M20 SM-M205M but something went wrong once the Odin finished cause it got stucked on a bootloop. Then i realized that the name of the file i was using was "ROOT-M205F-U1-Android 9 Pie.tar" i guess that was not made for my phone version. After a short investigation i downloaded the SM-M205M Firmware from Sammobile, it came with 5 files and i put each file in its respective field (using Odin 3.14.4) i tried to follow the instructions.
-The phone is in download mode
-Im using my original usb cable
-Odin recognizes that the phone is conected
-I have the Samsung drivers installed
But when i hit the start button it says Fail and a sentence appears in the upper left corner of the phone screen "CHECK FAIL(BOOTLOADER) DEVICE: 4 BINARY: 3", so now im running out of options, i would appretiate your support, thanks.
