First of all I am totally exhausted,
I study 10 hours (approx) a day and this Phone is only companion.
I only use GooglePlay apps, none other.
My phone doesn't get charge when it's off. but when on it doesn't either.
but this method from another Forum, WORKS:
*This happened to my phone and it really is a simple fix. First take the battery out of the phone for about 10 seconds. Then with the battery out plug the phone up, wait a few seconds, and put the battery in and immediately press power. Should be as good as new.
# and really it did work. I could charge. but again same problem.
1. keeps charging after unplugged , when phone is off does not charge.
2. again applied that method it does work. and happen No. 1 again.
CHARGER is ok (TESTED)
