galaxy nexus problem!
Moussa12
hello my friends i have a galaxy nexus and on the black camera area there is a white material not a scratch that looks like can be cleaned but when i tried to clean it it didn't go away it's shape is like a line and barely visible but when in a good lighted room it's very visible please does anyone know how to remove it because the phone is just 2 weeks old and it's really bothering me.
is nail polish remover good to try?
Welcome to the forums Moussa12, glad to have you here :)
Sounds like you have a hairline crack to me, on the camera, have you dropped the device at all, or were you able to take a good look at it right when you got it to see if it was there?
Otherwise i would suggest to return it and get another device.
I would suggest some multi surface cleaner if you are looking for more options though, but it sounds like what i said from the start, since you have to look at a certain angle to even see it.
Sorry for the bad news :(, thanks for joining though!
:wavey: Glad to have you join, sorry to hear about your issue.
images
