galaxynoteedge
Hi there! So I was painting my nails a bit ago and I dropped the polish and it splattered, landing on my tablet. Without thinking I freaked out and wiped it off using a nail polish remover pad. I googled afterward and realized how bad this was and immediately washed it down with water then some alcohol. The remover pads were acetone free and there is no evident damage on the screen or functioning of the tablet (I'm using it to write this actually). Anyway from what I gather the damaging ingredient is acetone which there was none of in these pads. I just was hoping for some piece of mind that don't wake up to a massive hole burned through my screen.
