raiderleaf
Member
Hello everyone,
Like many of you, I got my GN II today (Verizon) and I'm trying to get it set up. I'm surprised that it is this difficult but I'm hoping that the community might help me get things figured out. Here is a brief list:
1. Email - I get a lot of e-mail per day, some of which I like to delete completely (off the sever) and others I like to keep on my device. On my BlackBerry, whenever I went to delete something it used to prompt (Delete from Device & Mailbox or just Delete from Device). Can anyone tell me if this is doable?
2. Calendar - I noticed if you use the S-Pen to write on the calendar, and then you try to click into an appointment, it won't let you do it. It forces you out of the S-Pen mode and once you do that, what you've written with the S-Pen is gone.
3. Multi-Window - I cant seem to add any of the other stock apps to the Multi-Window, not even Calculator. Also, when I'm in a call and I pull out the S-Pen, the S-Note pop up window comes up, but if I put it full screen, I can't find a way to turn it back into a floating window!
Please help if you can, although my number one concern is the e-mail.
Thanks!
Thanks!
