Help Galaxy Note 3 questions
Jeffruby
A bit of help would be appreciated. Thanks.
1) any way to get rid of the notification "hands free mode turned on"? Is driving me mad
2) when I pull out the spen, I know how to click on a clipboard in a field to start to write in script or print. What I can't figure out is what to do on the screen that had the area to scribble with pen (makes blue line), and has that tape measure type strip on bottom. I see this area in place of the keyboard when I click on a field for text entry. ie-clicking field, not the little clipboard
3) Amy way to decrease the long press time on nice Samsung keyboard?
Figured out 1 - 2 above,Now Justcant figureout how to set a Comma on the default keyboard to the Left of the Spacebar . Anyone?
I Figured out 1 - 2 above, now I can't figuree out how to set a comma on the default keyboard to the left of the space bar. Anyone know how to do this?
Press your finger on the icon immediately to the left of the space bar on the botton row of keys on the Samsung keyboard until a mini menu option pops up with the comma available
SwiftKey, SwiftKey Beta, Google Keyboard and Kii Keyboard are a few of the many keyboards which have the comma to the left of the space bar by default without having to hold on any button to access it.
Thanks for your help! Unfortunately on my Samsung keyboard, when I hold that icon, I don't get the same popup... Just the bottom row you have
Look for the "Samsung Apps" application on your phone and see if it updates. If no updates are available then I would suggest using the similar application which is free called "Google Keyboard". You can also install SwiftKey Beta for free by clicking the web link below:
http://bit.ly/skemojibeta4-5
Thanks again. I wonder if it is a different keyboard on Verizon. I have Verizon and look for all updates but could not find that, option on the second key to the left of the space bar
Try a long press on the period (full stop) key o the right of the space bar.
Well, that works but just for a second. I've seen pics of people setting the button to the left of the keyboard as a comma. Not on my Verizon phone.
