How To Galaxy Note 4: How to delete apps
This resource created by Phandroid.com Contributing Editor Kevin Krause as part of an Official Series of beginner tutorials for Android Forums.​
To delete apps from your Note 4, follow these simple steps:
  1. Open your app drawer and locate the app you wish to delete
  2. Long-press the app icon and drag it to the trash bin icon labeled "Uninstall"
  3. Confirm that you wish to uninstall the app.
Note that you will not be able to uninstall most apps that came preinstalled on the device without rooting your phone, an advanced procedure not recommended for beginners. Any apps you download from the Play Store, however, will be easily uninstallable at any time.
