Galaxy Note - Gingerbread/ICS Update - Help!
I have the Samsung Galaxy Note, and when the leaked update of the ICS came out I tried it (wrong decision)! Anyways my phone thinks that it's running on ICS and GB at the same time:
Kernel Number 2.3.6
Baseband Number i717uclc5
I can't update my phone to full ICS and it's still on gingerbread, I also can't root it, or flash it back to GB (I tried downloading the stock ROM and using ODIN but that didn't work).
Can anyone help me, to get it back to full gingerbread, or update to ICS, or root. Anything would be helpful!
Thanks!
Best thing to do
Step 1, download and install kies (not kies mini)
step 2, pull your battery and write down your S/N (not your IMEI number but the serial number)
step 3, start kies and then turn the phone on and go into download mode (hold volume down, when prompted press volume up)
step 4, let the drivers install
step 5, once all that is done, in kies, Choose Tools, Firmware upgrade & initialization
step 6,
a) While in download mode, enter the S/N & model name (ALL CAPS!! SGH-I717 not SGH-i717)
b) It will prompt to initialize to original settings. Click "YES"
c) It will prompt to initialize the latest version. Click "YES"
d) It will download the firmware upgrade components (DO NOT DISCONNECT THE DEVICE!!)
Setp 7, Kies will prompt for firmware upgrade and initialization.
a) Click check box for reading above information
b) Click your choice if you want your information saved on Samsung Kies corporate servers (I choose WITHOUT saving).
Now walk away from your phone for 15-20 minutes. When you get back your phone will be 100% stock and on the official ICS :)
Original credit for this here: http://forum.xda-developers.com/showthread.php?t=1731654
If you want to go back to GB, it is a longer process, but PM me and I'll walk you through it.
james27007 thanks for the tutorial on upgrading from Gingerbread to Ice Cream Sandwich. Do you recommend doing this? My phone is having all kinds of quirky problems. Difficulty using USB to transfer from phone to pc, random shutting down, no internet connection for days at a time, etc. It is still under warranty with Samsung, but they want me to send it to Texas for diagnosis and it will be gone for several weeks. This is my business phone and I can't do that. Please advise on what you think is the bet course of action. Thank you.
hi! I neead the GB rom to restore my i717, I have baseband unknown and imei null , gps not working,since the upgrade to ICS. I have looked 4 it , and I cant find it anywhere. every link is unavailable
