A
Android Question
Guest
My android device (Galaxy Note N7000) is in original factory Android updated to Jelly Bean (4.2.1). Now its started showing low disk space warning even if there are less apps and all Moved to SD card. All cache is cleaned. If i see my System Disk using DiskUsage app then it shows System data of 993MB, which goes on increasing in size even if cache is cleared or app is removed.
How to reduce the system Data.. Please help and suggest some way.
