Galaxy Note Software Update issue.
Hi ,
I don't get software and facebook updates when Galaxy Note is connected to WIFI networks. I get updates only when its connected to data network. Kindly suggest!
Thanks!
Hi Diabloandriod.. :)
Welcome aboard.
The problem you are having could be "internet connectivity" with the connection of the wireless internet. This could be caused by several things.
You could try a few troubleshooting steps:
1) Reboot router and device.
2) Forget network and sign back in with password.
3) Check inside your device's support forum to see if anyone else has been experiencing the same problem.
Best of luck. :)
Welcome to Android Forums, Diabloandriod.
I hope the suggestions Rush above me made help you get your problem resolved.
Hope you enjoy your time here! :)
