Help Galaxy S 4G FAQ's
mavictb
Q:What is the internal memory?
A:1gb internal with a 16gb external card included.
Q: Does it lad like the Vibrant?
A: No, it is very snappy and responsive.
Q: Does the GPS work like crap like the rest of the Galaxy S devices?
A: No, in fact it has 5sec. cold start locks with consistent 5m accuracy.
Q: Is the compass useless like the one found on the vibrant?
A: No, it works just as it should.
Q: can it be rooted?
A: yes, it can be rooted using the rage method. that said there is no ROMS and no Clockwork Recovery yet.
if you have any other questions I will try to answer them and add them to the OP.
ok so a few questions for ya. What is rooting? what is it good for? How do you root a phone?
I'm trying to copy and paste in my emails and its doing nothing, do you know how i need to copy and paste in my yahoo email?
I'm trying to get my phone to read all the music off my sd card, and i can't get it to do that, do you know how i can do that?
Last question, how do you tether this phone? I used to be able to do it with my blackberry b/c it had to option on the desktop manager, but i don't know how to do it with this phone.
Sorry for so many questions, but i just got my phone so i'm trying to see what all i can do with it. Thank you so much for any helpful advise you can give me.
Kati
Go to settings, wireless and network. It's under that.
I think you might have to set up a folder for your music or find the folder that the player reads. I had to set a folder up just for ringtones since I use .mid
I am a pretty new owner of one of a Galaxy S 4G. I am on the Sprint network. It got updated recently to 2.2.1. While I like the silencer on the notification bar, orientation sensing got sluggish, notification ringtone got substituted and would not restore from settings, sound. This may be user ignorance. Is there a function I don't know about that will now set different sounds for an email notification and a text notification? Thanks for taking the time. I'm also curious about the risks/advantages of root for this device. Sorry to bother you about this if there is a well-known faq or other ref, but this forum is the best thing I found by googling the question.
I use Verizon and when I look at my texts there are some threads that the person's name highlighted in color and others that are white. Why is that?
Also, I have an IMAC and when I plug in my phone to grab songs off of the IMAC Itunes does not recognize the phone.
Any easy instructions ? I tried using some other advice using downloaded apps but kept running into problems. Thank you.
I know NOTHING about cell phones. I just got the Galaxy s 4g and it wont send texts that go over 1 text (over 160 characters). I like everything else about the phone, is that a problem with ALL galaxy s 4g phones or if I exchange it do I have a chance it wont happen with the new one???
