Do you have wifi on or do you use the gallery a lot?
Gallery is a batterydrainer by itself.
But wifi uses more battery i've noticed
I've noted that at work my wifi doesn't seem to sleep (even though I have the 'sleep when screen turns off' option selected). Also it may be because of a slightly higher usage over the last 2 days since I did a factory reset when I put 2.2.1 on.
In the battery status is shows screen as taking most of the power and wifi/android at roughly 2% each.
