Help Galaxy S Help
yeah its the only official way to update the galaxy s. it gives you the most current version of android that your carrier supports
last question ...
are this phones with the same carrier/locked sim as iphones ??
are they same problematically ?
yeah . but .. is it so problematic , buggy if it is unlocked and used like iphone ?
cause iphones unlocked are practically not very stable
Here are two links from the Samsung and AT&T sites to assist you in any support or update issue you wish to perform, or solve.
If you take your time, read and follow the instructions properly, I can assure you Kies is very easy to work with.
You need to download the latest version, which is often NOT the version that is listed in other places on the web. This is where 95% of the problems come from.
Patience and careful attention to detail will give you the result you want, fast and easy.
I know, I've done it myself.
Cheers :)
Official Samsung Galaxy Support
Get Downloads, Firmware, Manuals and Software for Samsung SGH-I897ZKAATT
Official AT&T Galaxy Support
Learning Center
