Help Galaxy S... Or Galaxy Ace?
Okay I Know Its A Stupid Comparison, But I just Want To Do It :)
See, Where I Live, The Galaxy S Is Just a LITTLE more Expensive Than The Ace, And Im Okay With Paying That Little Extra
But I Need To Know, Which One Should I Choose?
I Know Feature Wise The "S" Is Better Than The Ace, But What About Upgrade-ability?
What Phone Would Still Be Good In The Future Out Of The Two?
A Phone That Wont ..... Die off Fast?
And This Is Stupid But Does the Galaxy S Have A White Back Cover? :D
Thanks Guys, I Need Opinions Fast, Might Buy It Today
As an SGS owner and helping a colleague with an Ace, personally I'd say there isn't a comparison as the Ace has smaller lower res screen.
Kind if found it a bit irritating that the icons etc didn't look that good.
On your other question then as a first choice I'd not select either at the moment as the S2 would be a better choice with a view to updates etc.
Seem to recall wasn't clock speed but the type of processor.
Adobe have minimum specs and from what I recall the Ace doesn't meet them
Guys Turns Out, For A Little More Than The SL, i Could Get The 8GB "S" Version, Which Has the AMOLED screen, so better, right?
I Think Ill Go For It, Or I Might End Up With The 4GB SL If The 8GB Is Not Available
Hi Not sure if it helps but i had the ace for last month well 2 actually its an awesome phone but it has a flaw it turns its self off and only way to get it back on is to take the battery out and start it up again, very annoying !!! so i have just ordered the galaxy s 8gb been told its alot better in every way except when taking photos (which is quite important to me) it has no flash
Well You'll Be Happy To Know Ive Got The Galaxy S 8GB Instead Too :)
Its Pretty Awesome, No Flash Is True, But Thats Not A Pretty Big Issue For Me, It seems to cope well
Think a bit of confusion here
we were talking about Flash i.e. add in to allow certain web content
and now its about flash in connection with the camera and of course the SGS doesn't have a flash for the cam
