Help Galaxy S with ADW Launcher???
SupremeBeaver
I have searched high and low on the net trying to find a video of the Galaxy S with ADW launcher. I cant really stand the samsung launcher and want to see how it would look with ADW. Can one of you kind folks here install it and upload a video? I dont have the phone personally but im trying to convince myself to buy it seeing as its the best phone available in Europe and there seems to be nothing good coming from HTC or Motorola.
Also if i was to install either ADW or Launcher Pro on the phone, would that remove all the blue that samsung themed the phone with? Like the notification bar and all the icons in the bar. Check this pic if u dont know what i mean
There is no blue theme. It's mainly black.
And yes, any of those home replacement apps (ADW, GDE, LauncherPro, Open Home, Sweeter Home, Panda, etc...) will all work on this phone.
It won't completely remove the TouchWiz stuff, but it will definitely change it. I personally like this version of TouchWiz. Very nicely done this time around.
Hi there, I'm running WCD launcher on my SGS, was the first app I downloaded. It runs exactly like it does on any other phone, I can't readily post a video.
There is still lots of blue knocking about, too much for me. I much prefer the black/grey of stock 2.1 myself.
I use found the phone to stutter a bit with all and home launches so I am going to try another launcher.
Apart from the Samsung muck the phone is great and clearly very powerful. Can't wait to see some ROMS that clean things up and let the phone shine :)
After a few days I've ADW launcher I've switched to launcherPro. First impressions: faster, cleaner, more stable, less hangs. Better.
i love that blue accent thats all over the Galaxy S. I actually have the exact theme to mimic it now on my moment. Its called dark blue theme. My notification bar is black as well.
I've tried both ADW and Launcher Pro, both seem to be roughly the same but LP seems to run a bit quicker so I've stuck with that for now.
After 24 hours with ADW.Launcher and 24 hours with LauncherPro, I've gotta say LauncherPro is the better pick by a long way.
Much faster, no crashes (compared to at least 3 FCs I can remember under ADW) and the animations can be sped up without going all jerky.
I dont mind the default TouchWiz setup though, its pretty stylish.
...I dont mind the default TouchWiz setup though, its pretty stylish.
NOTE: Don't have the phone yet for personal experience.
But on my current old phone, I certainly needed a custom launcher. So having had that, I definitely am used to having a very personalized screen.
I have been impressed with the various videos I've seen of Touchwiz 3.0. But none have had screens as I would set mine up.
My question is: if a person installs one of the custom UIs does it take away any of the standard UI features? I don't want to cripple or disable that, but enhance the customizability.
Maybe I wouldn't need a custom launcher based on what I said. I'm anxious to get a new phone. If it ever comes available :p
Aftyer installing LP many of my shortcuts, widgets and programs were not visible on my Galaxy S at all. Normal or some setting, and why? Thanks
Normal behaviour, if you change to a new home launcher you need to reconfigure the screens (widgets, etc.).
Because each launcher stores its settings in it's own /data/ folder, these settings are not shared between launchers.
Touchwiz looks really good,all the other launchers look kinda cheap when compared to it.If you want speed, opt for launcher pro(but i personally like side scrolling of apps)
I've been using LauncherPro for a few days now.
I find the dock much less intrusive that the TouchWiz one. I do however like the 3D app drawer, which works very nicely.
I am using the ADW launcher and love it! Touchwiz is too iPhone'ish for me and coming from a 3g iPhone I wanted something different, once I knew what the home screen on an android should be like :) Is very fast with ADW Launcher and lots of options to customise, so far no complaints after a week.
