galaxy s2 jelly bean rom boost mobile
chevyman1
Can anyone give me a link for a jellybean ROM that works with boost mobile galaxy s2....and maybe a cwm recovery link also or know where to find one? I was thinking maybe cm10 ROM.... Any help would be awesome thanks.
I just want to make sure all that will work with boost mobile version since it says Sprint on all of them I have seen... And is GB27 a jelly bean ROM? Thanks
All the JB Roms from sprint work with the S2 from Boost Mobile. I have been using the Sprint JB Roms since they started showing up, and recently I installed the GB08 on 2 other S2s from Boost. As long as your phone is activated with Boost before you flash it, you should be just fine. I'm running GB27 and it works great.
All the leaked and custom ROMs have Sprint labeling. They work just fine, and only need an adjustment to the server settings for MMS messages to work. Yes GB27 is Jelly Bean
go to selfs one stop shop. you passed it on the way here. there are a lot of answers there. i would read all i can about what im doing. first get your msl from boostmobile. it can be had for the asking. find out about the emmc brick bug before flashing. im running tbsgs3 gb 27. sweet.....
I looked and can't seem to find the GB27 ROM anywhere if someone could give me slink that would be cool. And do I need a modem to download for that? I want to keep good 3g speeds as well as 4g if that has anything to do with it. Thanks again
Thank you very much. So all I need besides that is the agat kernel so I will have a custom recovery?
You can't use the AGAT 068 kernel with this ROM. That is a ICS kernel. There is a Repack of kernels for TW JB but they have some issues, and so I don't recommend using the repack kernel as a daily driver.
im sorry if this sounds dumb but don't I need a recovery to make a backup before I flash the new rom? so what im understanding is to flash the agat kernel then make a backup, then flash the new rom without a recovery and it will be ok?
Yes you will be okay. Just keep a copy of that agat kernel with recovery handy should you want to go back to the ROM you had before. You would Odin in that kernel then boot into recovery and do a restore.
I have started working on a Rom built from the GB27 leak can't say how well this will go (Since I have never messed with JellyBean, but hopefully I can bring 187MoD flare and a little life to this community.
:beer::car::beer::car::beer::car:
