Galaxy s2 modem issues
dave1967
Hi all
Not sure if im posting this in the right place as only just joined so sorry if i should have posted it in a different forum.
I have recently bought a Galaxy s2 on 3 with unlimited internet when i tether it to my laptop it works fine except on a lot of sites the pictures dont display..however if i log on using my 3 dongle with a different sim card and go to the same sites the pictures display fine..is this a phone or a laptop issue..any help would be greatfully appreciated.
Cheers
Dave
Hello and welcome aboard.. you might just need to clear "cookie data, cache, data, history from the web browser. On any webpage, tap menu, more, then settings." If this doesn't work - then you would need to check in to your device's area of support for help.
Since there are a few variants of this phone, and I'm not sure which Samsung Galaxy S2 device you have, ivevwent ahead and posted all the links for them.
Samsung Galaxy S2 (AT&T) - Android Forums - (AT&T)
Samsung Galaxy S2 (T-Mobile) - Android Forums - (T-mobile)
Samsung Epic 4G Touch - Android Forums - (Sprint)
Samsung Galaxy S2 (International) - Android Forums - (International)
Samsung Galaxy S2 Skyrocket - Android Forums
Samsung Galaxy S2 Skyrocket HD - Android Forums
Good luck.
Youve lost me straight away sorry..do you mean menu on the laptop or phone..also how do i know which version of Galaxy s2 im using..sory to sound stupid but really frustrates me..many thanks.
You are on 3 as your carrier? As in you are in the UK? You're using the international version. Basically, if you aren't in the USA, you're using international.
And he means menu in the phone.
