galaxy s2 wont turn on
  • Start date Start date
A
Android Question
Guest
I have a galaxy s2. I had the screen replaced ad when I put the battery in the phone started to turn on but it gets to the android logo and then goes off then it continously vibrates. I did some checking and figured the on off switch was bad so I had t replaced. It still does the same thing. Any ideas on what i should try next?
Instead of telling them what to replace, say "make my phone work". You can't complain if they followed your instructions, and that didn't solve the problem. If they diagnose it and guarantee a repair, it's on them.
