Help Galaxy S3 Charging Problem
My new samsung galaxy s3 has some charing problem, its taking long time to complete the charing am not sure that my charger is damaged
Try a replacement charger. Mine had this problem, although not new when it happened, and a new charger sorted the problem out.
If it continues with a different charger then it's probably best to take it into a shop and see what the problem is and maybe get a new phone
Try to define long time. How long does it take to charge? Are you charging via USB on a PC or with the supplied Charger?
