Galaxy S3 is awesome! Here's why...
Mabaet
Worth reading... please do. And I hope somehow this enlighten you about S3 and make a good choice.
First of all... not all of the information here is mine stated... I got some from reviews or comments of other people or some stuff thing yeah. I'll be keeping this simple and easy.
Samsung Galaxy S3's design... explained:
Samsung Galaxy S III Design: Explained! - YouTube
I agree HTC One X have a BETTER design... but that doesn't mean Galaxy S3 is bad already. Why always one x? Look at other high end smartphone in the same class.
This is LG's latest
Is that old boxy feel better looking than this sexy beast?
Why can't people understand that plastic is a not a bad option. Look at the bright side. It can flex, it's got one of the best strength to weight ratios, it's not going to smash like glass, it's more shock absorbent, it does not cause a disturbance with radios, it does not conduct heat the way metal does, and it's much lighter(hmm but still htc one x is lighter :D). It is also improved to be more less scratchy. Also it gives smooth looking :p
Wondering about the screen as being PenTile? Here's the reason... plain and simple. Because PenTile will make it last LONGER. You should not worry about the image quality... thanks to its high ppi density the PenTile matrix. Why the hell would you bring a magnifying glass to see the concern when you can look at it normally as you always do and it will look fine and beautiful.
Even if the design is far from perfect, few people will actually be looking at it too closely. Who will waste time looking at the back of it, when there is a screen as gorgeous as this at its front?
The design is perfectly made to fit in hand sexily.
Galaxy S3 have removable battery... and a micro sd slot when one x doesn't have both. And even if GS3 has non removable... it is still more juicy than one x's battery.
Benchmarkings... Samsung Galaxy S3 wins over HTC One X at almost every test.
Camera in same pixels... but more improved performance and quality. SAMSUNG GALAXY S3 HAVE BETTER CAMERA PERFORMANCE BOTH VIDEO AND IMAGE CAPTURING OVER HTC ONE X.
Awesome features/extras:
-S Voice
-Direct Call
-Smart Stay
-Smart Alert
-S Beam
-Buddy Photo Share
-Pop Up Play
The Samsung Galaxy S3 have something that other high end smartphone can't do. (How their Motion Gestures work, how file sharing works <<< Awesome indeed)
Every smartphone has its own flaws. Nothing is perfect.
If you ask me if s3 or one x. I'll go for s3. the one x's design is awesome indeed... but everything else i'll go for s3. Well... s3 will be more expensive though... :eek:
Samsung Galaxy S3 kills HTC One X Video. The only thing negative in the video is the design and material used, but what I said earlier... you know what it is.
That's it for now... thanks for reading =] :rock:
It's on my list to purchase, but really I'm going to have to see what is out there when/if it comes to VZW. That is a long way out from what I can tell from all the posts. It's the best now, I like its looks also, but there are always new phones coming. By time Q3/4 comes around, this may be outed by something better. The S3 is the only one that meets my needs:
HD
AMOLED
SD card
Removable batt
4.3"+
Either S4 or quad core.
Lol I feel the Huawei Ascend (D Quad) beats the SIII in hardware AND software, and/or possibly marketing... We'll just have to wait and see till the final model Ascend lands.
The only thing that really impresses me about the SIII is the homescreen being free of lag while changing between them while being loaded with widgets, and even with a live wallpaper going. However I have heard this is true and also false, not sure who to believe... And looking forward to seeing some SII vs SIII camera shots.
And build materials undoubtedly. Until Samsung decide to change the way tey build their phones I am probably going to stay with Moto.
That's valid point and I know many don't like samsung phone for this reason. But often look and hand feel don't go together and I normally use case anyway. At least sammy phones are better than average on drop test.
I like samsung for their display, camera, good battery life and processor. One X looked attractive at first but I came to dislike it after seeing small fixed battery, no micro sd. And it seems they severely restricted multi-tasking with Sense 4.0 in One X. Moto is my next favorite after sammy but they continue to baffle me on the camera, display departments.
I would choose SGS3 over One X, but that is not the point.
