Well randomly the music icon ( the pause and play) appears on the top notification bar, I'm not even playing music, I may be just on the internet or Twitter or something and it will randomly appear, does anyone know why? I have done many virus scans and found nothing![]()
Hi do you get problems when you are playing music and it stops by itself goes on pause?
If you are then go to settings go to language and input then go to voice cmd four apps and turn that off. Voila
Hope that helps
Super annoying so I just stopped rejecting calls.Well randomly the music icon ( the pause and play) appears on the top notification bar, I'm not even playing music, I may be just on the internet or Twitter or something and it will randomly appear, does anyone know why? I have done many virus scans and found nothing![]()
