Help Galaxy S3 Settings question please??
OKay so I can't figure out how to revert back to the original setting of something.
I have the Zedge app for ringtones/notification tones.
When I go to my settings and click to change my ringtone, it always brings up a message that says "Use zedge just once or always, or use storage once or always" And I accidentally clicked "use storage always".
How do I go back to where I get the option to use storage or zedge when I want to??
Thanks for any help
Go into your Application Manager. Select the Zedge app. Tap on Clear Defaults.
But I didn't pick Zedge as the default app. I chose "storage" or whatever it says. So when I go to the app manager and click zedge, the "clear defaults" is grayed out. I can't select it...
Welcome to AF, ShelboTron!:)
I have moved this thread into the S3 forum, where those with the same phone can post their tips to help.
Try clearing the Media Storage app maybe? The way Zedge works for me is I go into the app itself and download the notification sound/ringtone and then it automatically shows up in the ringtones list on my phone. I don't have to go to the Zedge app itself when I change the ringer. The ringer is just there in the list.
If you go to Settings >Applications Manager > Media Storage and clear the default there it will let you choose which app to use next time :)
There is no media storage in my application manager...
It just shows all the apps I've downloaded.
Ugh this is frustrating!! :/
