Hello and welcome to Android Forums. Hopefully I can help you with your problem.
Open up your settings and then go to application manager. Once you are there, look under ALL. You will see the option to clear data. Select it. That will reset everything and should get you taken care of.
If you have any other questions regarding your device, I invite you to join Android Forums. We have many sections for specific devices which contain a wealth of information.
