Galaxy s3
  • Start date Start date
A
Android Question
Guest
I have an app that I need to see in miles and not kilometers. I do not know how to change it on my Galaxy S3...tried a couple things but it hasn't worked. HELP !
Which app are you trying to use. That would help answer your question as the settings should be changed in the app.
Thanks
I have downloaded the c:geo app. It is a geocaching app telling the distance to the geocache from where you are located. It is showing up on my new phone in kilometers instead of feet and miles. Had the app on my old Android phone and it was in the correct measurements. My phone is set to English language.
Thanks all for trying to help me, but I finally figured it out.....I had to go in the app and change to imperial units !! The app is set to metric by default. Lesson learned ! :)
